Unbound Unbound and dnscheck results
swejuggalo
I decided to try out Unbound on two routers. Both starting to climb over 60% hits. Pretty much basic setup.
However, there is a major difference.
https://dnscheck.tools/ shows extreme different results.
They show drastically different ping.
The biggest difference is that AX88U don't use Diversion. But AX88U is the one that generally have the bigger workload.
They are running solo and have their own external IP.
Tried searching and digging but I can't really explain this behavior. It feels like I have no more things I can check to prove what could cause this.
It's in the area of being steady at approx 30 (AX88U) to peaking at 500 with lows on 200 ms (BE88U).
