Unbound Unbound Stats for Asuswrt-Merlin v1.4.5 [2026-Mar-23] Generate Stats for Unbound
Martinski
Release Notes for Unbound Stats v1.4.3 production version now available
[2025-Aug-24]
1) NEW: Added checkupdate and forceupdate parameters to make it easier to update the script without forcing users to first uninstall and then reinstall.
Bash:
/jffs/addons/unbound/unbound_stats.sh checkupdate
     #OR#
/jffs/addons/unbound/unbound_stats.sh forceupdate
2) NEW: Added develop and stable parameters to allow users to easily switch between the production and the development branch versions when/if needed.
Bash:
/jffs/addons/unbound/unbound_stats.sh develop
     #OR#
/jffs/addons/unbound/unbound_stats.sh stable
Note that the initial installation *should* still be done via Unbound Manager. The above new parameters are intended only for an already existing installation.
3) IMPROVED: Modified the call made in the service-event script to check if the parameter contains the script name.
4) IMPROVED: Modified the startup call made in the post-mount script to check if the USB-attached disk partition passed as the argument has indeed Entware installed.
5) IMPROVED: Modified code to set the corresponding priority level of log entries when calling the built-in logger utility.
6) Miscellaneous code improvements, error checking, and fine-tuning.
NOTE:
Currently, the Unbound Stats add-on is not officially hosted on the AMTM-OSR repositories due to its inter-dependency with Unbound Manager, which is also not hosted on the OSR repos at the moment.
"Currently", "at the moment"... so both might reach OSR. Hurray! ;)
I cannot find a way to install unbound_stats via unbound_manager
There does not seem to be any option:
What am I missing?
Release Notes for Unbound Stats WebUI v1.4.4 production version now available
[2025-Nov-03]
1) FIXED: Removed old Tomato JavaScript dependencies and replaced code with more standard function calls.
2) Minor code improvements.
NOTES:
1) To check the currently installed version of the Unbound Stats WebUI add-on, run the following command on an SSH terminal window:
Bash:
grep "readonly SCRIPT_VERSION=" /jffs/addons/unbound/unbound_stats.sh
2) If you have the latest production 1.4.3 version, run one of the following commands to update it:
Bash:
     ##OR##
3) If you are running an older release (1.4.2 or earlier), you can install the latest production version with the following set of commands:
Bash:
curl  -LSs --retry 3 --retry-delay 5 --retry-connrefused \
https://raw.githubusercontent.com/juched78/Unbound-Asuswrt-Merlin/master/unbound_stats.sh \
-o /jffs/addons/unbound/unbound_stats.sh && chmod 755 /jffs/addons/unbound/unbound_stats.sh && \
/jffs/addons/unbound/unbound_stats.sh install
4) To double-check that you have the latest production 1.4.4 release, run the following command:
Bash:
/jffs/addons/unbound/unbound_stats.sh help
[2025-Nov-03]
NOTES:
Bash:
Bash:
     ##OR##
Bash:
Bash:
@Martinski we appreciate the continued support for Unbound Manager. I noticed in GitHub page that there's 3 issues still open at this time for Unbound Manager. I don't think these issues have been either verified and/or addressed/fixed for this current version correct since this only fixing the stats.
Again thank you for all you do (plus all other developers here)!
Issues · MartineauUK/Unbound-Asuswrt-Merlin https://share.google/xASsN27KwrFPLaBE8
Just to clarify and set the proper expectations.
I have not taken up the role of maintaining Unbound Manager. So far, I’ve been fixing issues only with the UnboundStats WebUI part of it (a separate project on its own GitHub repository). Initially, my only goal was to try to keep the WebUI page working after several changes in the recent F/W versions that were breaking many of the add-ons webpages, and that goal has not really changed.
I realize that at some point, it would be required to fix issues with Unbound Manager as well, but frankly, I have reached my limit of the number of add-ons that I can keep supporting and maintaining. I simply don’t have enough spare time in my evenings and weekends to add one more project to my already full plate.
Perhaps someone else has the time and is willing and able to take Unbound Manager for support and maintenance. I would certainly help that person whenever I can, but they should not expect my full involvement and commitment at this point.
Its understable and I appreciate the additional information!
Release Notes for Unbound Stats WebUI v1.4.5 production version now available
[2026-Mar-23]
1) FIXED: Removed a remnant function call from old Tomato JavaScript code (i.e. comma()) that was causing errors when calls to show tooltips were made.
2) IMPROVED: Added the process ID to all syslog messages.
3) NEW: Added code to support "Automatic Script Updates" via AMTM.
This new functionality requires AMTM 6.4 or a later version (see caveat below)​
CAVEAT:
Currently, AMTM does *not* show version information for the Unbound Stats WebUI add-on, so it doesn't show when a new version update becomes available. For some reason (that I'm not aware of), Unbound Stats WebUI was never added to AMTM. I'll discuss this with @thelonelycoder to see if we can work something out to get Unbound Stats WebUI included in AMTM.
In the meantime, if you have already installed v1.4.3 or a later version, you can simply update the add-on by running the following command in a SSH terminal window:
Bash:
To double-check that you have the latest v1.4.5 production release, run the following command:
Bash:
