Unbound Unbound Stats Tab (GUI) not showing?
Daniel LaRusso
Noob here, but how do I install the Unbound statistical tab (web GUI)? I'm using an Asus AC86U with the latest Merlin firmware. I installed Unbound through amtm, I also have Diversion installed and Skynet. I see no option for adblocking or the statistical tab. I've uploaded a screenshot of what I see when I open Unbound from amtm.
The 'Easy' menu should look like this
|  Welcome to the unbound Manager/Installation script (Asuswrt-Merlin) |
|                      Version 3.22b3 by Martineau                     |
unbound (pid 3792) is running... uptime: 3 days 01:08:36 version: 1.11.0 # Version=v1.11 Martineau update (Date Loaded by unbound_manager Tue Nov 24 16:52:44 GMT 2020)
1  = Update unbound files and configuration                     5  = Install Ad and Tracker blocker (Ad Block)
2  = Remove unbound/unbound_manager                             6  = Install Graphical Statistics GUI Add-on TAB
3  = Stop unbound                                               7  = Enable  DNS Firewall
4  = Show unbound statistics                                    8  = Install YouTube Ad blocker
?  = About Configuration
v  = View ('/opt/var/lib/unbound/'unbound.conf)
e  = Exit Script [?]
E:Option ==>
Is your SSH session Terminal window maximised?
If it is then you probably need to resize your SSH Client session window as per the recommendations on Github Read.me
You can use option 6 (even if it isn't displayed on screen)
