Unbound Unbound_DNS_via_OVPN.sh with Wireguard
Kingp1n
Dumb question but would the following script below work with the upcoming 388 fw to use with Wireguard?
Post in thread 'unbound_manager (Manager/Installer utility for unbound - Recursive DNS Server) - General questions / discussion thread 2' https://www.snbforums.com/threads/unbound_manager-manager-installer-utility-for-unbound-recursive-dns-server-general-questions-discussion-thread-2.67968/post-718328
Don't know if @RMerlin included the same hooks for Wireguard as for OVPN (like /jffs/scripts/vpnclient5-route-up) but in theory it should work the same.
Altough you could just bind Unbound to br0 address (192.168.1.1), and create the following VpnDirector rules
From 192.168.1.1 to Any route vpn
From Any to 192.168.1.0/16 route wan
As router would normally only use this address to communicate with br0 lan and since wan rules have higher priority in VpnDirector only Unbound will be affected. The same trick could be used by any application that could bind to a specific interface/address, i.e Transmission.
https://github.com/ZebMcKayhan/WireguardManager#setup-transmission-andor-unbound-to-use-wg-client
PS. You might need to adjust Wireguard dns back to router if you wish vpn clients to use Unbound, else they will be redirected to Wireguard dns.
