ntpMerlin uninstall command for NTPmerlin
GoNz0
I uninstall entware by accident, that's back on but NTPmerlins screwed, whenever you try to load it it says Creating database table indexes...
I can't find a manual uninstall command line and have given up after leaving it building for 2 hours.
Has anyone got the command needed to remove it?
(2 reboots didn't help)
*edit, found a thread with the info, all sorted.
Jack Yaz
Part of the Furniture
for future readers
/jffs/scripts/ntpmerlin uninstall
all of my scripts expose an uninstall command directly
GoNz0
Thanks for that, the only info I found was to kill the process and rename the file in scripts, after a reboot I could install it again.
