cool_recep
Hi guys,
AirTies Air5650 router with ISP firmware has its Torrent feature blocked. Is it possible to unlock?
Here are the Telnet commands for router:
Thanks you for your help.
BusyBox v1.14.1 (2013-02-01 16:32:18 EET) built-in shell (ash)
Enter 'help' for a list of built-in commands.
[ fcctl mdeltree set_ssid
[[ fgrep mdev sh
agent findfs mem_leak.sh sleep
airwpa free mformat smbcontrol
arp ftpd miniupnpd smbd
ash fuser mkap smbstatus
basbaglan fwversion mkdir smd
basename get_config mkdosfs stb_tracker
bestchan getenv mkfs.vfat tar
blkid getty mlabel tc
brctl grep mngr telnetd
busybox halt modprobe test
cat hostapd mount tftp
check_button hostapd_cli mount.fuse top
check_buttons hostname mount.ntfs touch
check_cfg_reset hotplug mount.ntfs-3g tr069_download
check_reset http_upgrade mpartition tr069_upgrade
check_setup_button httpd mrd tr64c
chmod ifconfig msntp traceroute
cli igmpproxy mtools traff_diag
configconvert init mv true
cp inotifyd nanddump udhcpc
cut insmod nasd udhcpd
date ip nmbd umount
ddnsd iptables ntfs-3g uname
defaults is_default_config ntfs-3g.probe unlzma
depmod iwconfig ntfslabel uptime
dhcprelay iwevent p910nd usbhost_test
dmesg iwlist pc usbtest.sh
dnsmasq iwpriv pidof vconfig
dsl_downstats kill ping vlanctl
dsl_statistics.sh killall poweroff watchdog
dsl_status klogd pppd wget
dsl_upstats led_test ps which
dsldiagd ledctl psi wl
dualimage ledtest pwd wlan_onoff
dumpleases list_managers.sh pwrctl wlconf
e2label ln qa_feedback_usb.sh wpa_cli
echo login reboot wpa_event
egrep ls rm wpa_passphrase
env_test lsmod rmmod wpa_supplicant
epi_ttcp lzmacat route write_dl_conf
ethswctl makedevs routed xdslctl
exec_cmd.sh mcpd set_bridge xtables-multi
false mdel set_config xtmctl
