Johno
Quite a while ago I registered a particular hostname for the DDNS service on my RT-AC68U which all worked fine, but since factory-resetting my router and re-configuring it, when I set up DDNS with the previously-used hostname, the status/config page reports that the hostname is already in use and that I need to use a new hostname. The public IP address hasn't changed, nor has my router, so the MAC address bound against the previously-used DDNS hostname should be the same now.
Is it possible to un-register a DDNS hostname previously registered? Using the Asus NSLookup page to check what IP address is registered shows the same IP as my public IP and as my router hasn't changed, the MAC should still be the same.
