Entware update available
Jeffrey Young
All went good for me upgrading. Only tick off was any of the /opt/etc/init.d/s* files that were edited by me for specific reasons were overwritten with default files.
Also, since wireguard was in the update list, the wg-up, wg-down, and wg-server scripts in /opt/etc/wireguard were nuked. Thankfully, I backup all that stuff. Was expecting it to happen.
gattaca
Thanks for the update. The entware updates seem to be the "nail-biters" for our amtm community. I see a lot of updates coming this time.
elorimer
Syslog-ng is updated to .31, but as near as I can see it does not introduce issues for scribe.
Mutzli
Updated my installed Entware modules this morning and the whole USB drive when down with tons of error message. Had to reformat the JFFS and USB drive and start over. Anyone else having issues with the latest Entware updates?
thelonelycoder
Part of the Furniture
Your drive would have been faulty before.
Mutzli
Strange, never experienced that before. I check this drive frequently and there weren't any errors in the disk check log. It's a USB attached SSD drive.
Kingp1n
The entware update stopped unbound for me. Just updated unbound and all is good. No issues once I restarted unbound!
heysoundude
yes, I had an issue with unbound after performing this update as well (there was an unbound component, IIRC) and may have mistakenly attributed slow/failing DNS lookups to amtm rather than unbound.
reboot fixed all...
ColDen
Same issue and solution as reported by Kingp1n.
elorimer
Yes, reboot required for unbound,otherwise no internet.
