amtm update menu stuck?
LaMpiR
Hi
I have a AX88U with the latest Merlin 386.8 and now when I log in into my router through ssh and I try to check for the update at amtm I get stuck.
Is there anything that I could do?
Tnx in advance.
Hit CTRL+C, that kills the process. Then open amtm again and run the update check command.
What other scripts have you installed? Share a screenshot of amtm.
I haven't changed anything regarding the scripts for a long time now. Update here and there, but that's it. This problem occurred only after upgrading to the latest Merlin Firmware.
https://bin.entware.net is not available for me. I don't know if that is relevant, but I assume that after those packages, it goes to check entware versions and there it gets stuck.
C:\Users\xxx>ping bin.entware.net
Pinging bin.entware.net [188.114.96.12] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 188.114.96.12:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\xxx>
Just to get that out of the way, disable Skynet and run the update check again. If it works, you will need to whitelist bin.entware.net.
