I'm looking to upgrade AC68 -> AX86U. For the initial setup for AX86U, I found instructions from L&LD (thank you!), which in summary appears to be as follows:
1) Factory hard reset (WPS NVRAM erase)
2) GUI-initiated reset to factory defaults (initialize... format JFFS.... restore...)
3) Flash Merlin
4) GUI-reset
5) Flash Merlin
6) GUI-reset
6) Connect FIOS modem to WAN
7) New 8 alphanumeric SSIDs for 2.4ghz and 5ghz
8) After router's been up for 15-30min, reboot router manually
Does that seem correct?
I'd also like to set up AiMesh using the AC68 as a node w/ a wired MoCA backhaul. My current setup is as follows:
3) Flash Merlin
4) GUI-reset
5) Flash Merlin
6) GUI-reset
- Verizon FIOS Gigabit (up/down)
- 3500sf 2-story home + basement
- Modem + AC68 (Access Point mode) on 1st floor
- 2 x Actiontec WCB3000N MoCa extender (basement + upstairs)
