Upgrade to 3.0.0.4_270.24
gemurdock
I upgraded my N66U from 3.0.0.4_264.22 to _270.24 from the lostrealm.ca site, and lost connectivity to my corporate host site through an AT&T VPN. Also my Outlook would not download pictures in email, but the rest of my connectivity seemed fine. I did not change any configuration settings, but I did reboot the router afterwards, any ideas? :confused: I backed down to the original firmware and the problems went away.
BTW, I have a USB thumb drive attached to the router, and it is working great for media files! :D
George
George
You should upgrade to something more up to date - the latest non-beta is 3.0.0.4.270.26b.
Thanks, that did the trick! I guess I should have read the change log text closer, I assumed that the "b" indicated a beta version, and I was looking more for stability than functionality, so I went with the old "n-1" version philosophy.
