Upgrading firmware versions
d_v_us
Hello, just trying to gauge what most people do when upgrading firmware versions, for example...I'm gonna update from 386.2_2 to 386.2_4 (not talking about any nodes...the master)....do most save ur settings and then restore them? I remember back in the earlier versions, I would just hand jam all the settings back in manually depending on the version or is that no longer a thing....I know I certainly hope not:)
ColinTaylor
Part of the Furniture
No, do not restore your previous settings after a firmware upgrade. Sometimes the new firmware has to migrate some settings from an old format to a new format. If you restored your old settings you would undo that process and potentially create problems.
By all means take a backup of your current settings and current firmware before installing the new firmware just in case you need to completely revert to your previous setup.
d_v_us
So yep....that's what I'm asking....before you upgrade...do you do a "wipe" or....just upgrade and then does it retain all ur settings from previous versions?.....sorry if this question is kinda basic knowledge:( In the past I would do a wipe (or reset) and then load new version.
L&LD
Your settings are not wiped when you flash new firmware on it.
If you want to give the new firmware the best chance to be stable, fast, and secure, a full reset (after you flash the new firmware) is recommended. Be sure you do not load an old saved backup config file afterward.
Fully Reset / Best Practice Setup / More
d_v_us
Aaaaah Mr. L&LD...thank you for responding....I remember your posts from back in the day:)....yes....ur wisdom and links are much appreciated. I had taken a long break from upgrading my Asus hardware but have recently invested in a couple of RT-AX86Us, ACs and getting back on track:)
ColinTaylor
No you do not need to "wipe" your settings before installing a new firmware, unless the release notes for the new firmware explicitly tells you it is required which is very rare.
386.2_2 to 386.2_4 is a very minor update. I'm not sure why you're not updating to the latest release, 386.3_2.
d_v_us
As far as why I'm not flashing to 3_2....I usually stay a few versions behind....just because I'm old school:) Nice and sloooooow.
Mathieu
I found myself within a forest dark, For the straightforward pathway had been lost.
Ah, those dreaded updates... I'm still sweating.
I am none the wiser, but do remember fondly the day when @john9527 proposed a Save and Restore tool. Bless.
If you want to avoid the Nuclear Option :) the nsrum [as yet not tested by me] package on amtm looks promising.
Do stay safe, and follow Colin's recommendations, though.
[Edit: Finishing sentence]
heysoundude
This may be common enough knowledge that it can go unsaid, but before flashing new firmware over old/existing, be sure to eject any USB drives you have connected to the router <- that's a best practise that people often forget/overlook.
The chances of a successful process seem to go up exponentially to "impossible to fail" that way...or come VERY close.
