awesomegiga
I do have problem with the upnp protocol since I've updated to the version 380.66. I do have my TV app and my panasonic TV, which they are supposed to be connect to the same network in order to control the TV via the APP. However, it only works if they are connected to the same frequency band wireless, i.e. either both to 2.4 or 5 GHz. Once they are connected to different wireless bands, they stop communicating. I guess upnp is used with TLS encryption. I am using RT-AC87U and start facing this problem in the last couple of firmware versions; I've test the 380.65_4 and 380.66 and both have are problem. What is really weird that some times its worked in different wireless band right after the restart and stop after short while.
