The case. I have travelled 300 km to replace a wireless router (with problems) to a new one. Everything work well with the new one, but as I only use it as bridge with an asus 68u after set up as vpn server I got the warning
The wireless router currently uses a private WAN IP address (192.168.x.x, 10.x.x.x or 172.16.x.x).
This router may be in the multiple-NAT environment.
The reason is that the wireless router hasn't been set to disable NAT. I have contacted the isp technicals but as they cannot be reached by phone, only by prority mail, I don't know how long it takes and may be I must stay over on a hotel if the isp technichal personel don't respond quickly.
My question is - can I use the client1.ovpn exported under this setup later when the NAT on the wireless router is disabled. (It don't work right now).
If the client1 file is the same as if it would be created later with not NAT problem, I can travel home and hope it work, but as I cannot test it before I need for advice.
Hope for answer before long.
