USB 2.0 LED remains on in stealth mode
HeadBanger
When trurning on the stealth mode on my RTAC68U the LED for USB 2.0 comes back on after a short while.
I see that a few others have had this issue see here for example.
Can I force it off somehow or just wait for a firmware fix?
HB
RTAC68U / Merlin 374.42_2
I have exaclty the same issue since I had active the time programe to swich on/off the radio wifi.
When I disconect it, the LED turn off again.
Could be the hardware bypassing the firmware code in activating the LED since I have plugged all visible places in the firmware that deals with LEDs. In that case, nothing more I can do about it. Implementing a watchdog timer just to re-disable the LEDs every few minutes would be a waste of CPU resources.
Ok, thanks Merlin.
I'm agree with you that implement a timer is not the best solution.
If you could find another solution for this issue it would be great, if not, only is a LED ;-)
