USB 3 device inacessible after factory default!
dugaduga
I performed a factory default and the usb3 thumb drive will no longer mount. I can still access the partitions just fine from a linux distro. Interestingly, i can see the partitions when i mount the drive in the USB 2.0 port. 3.0 is inaccessible. Im using the latest RT-AC68U_384.6_alpha2-g5b076fc87
Any idea how to fix this?
I've read that with usb 3 interference compensation disabled, some users had the same problem; I cannot find this option in the router settings any longer. I've looked under "professional" and "general" settings and I see no USB setting in there, and many other locations. no luck!
Does the USB 3 slot have to be mounted for this option to be available? Its late here and I must sleep, ill look further into this tomorrow.
