USB Disk Mounts Too Late - Deluge Creates Duplicate Mountpoint
bozolino
at boot time my usb disk seems to mount AFTER the deluge bittorrent client starts. because deluge already writes to /mnt/DISKNAME at start point (creating a folder there in the process), my usb disk mounts to /mnt/DISKNAME(1) - breaking all paths in the process. how can i prevent this?
Start the bittorrent with a delay to allow your USB drive to fully boot.
How to do it. Can't he get it in? Here's an example for how to put, an up to 60 seconds time delay inside the Entware startup script.
/opt/etc/init.d/rc.unslung
#!/bin/sh
PATH=/opt/sbin:/opt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
# Start/stop all init scripts in /opt/etc/init.d including symlinks
# starting them in numerical order and
# stopping them in reverse numerical order
#logger "Started $0${*:+ $*}."
ACTION=$1
CALLER=$2
if [ $# -lt 1 ]; then
    printf "Usage: $0 {start|stop|restart|reconfigure|check|kill}\n" >&2
    exit 1
fi
[ $ACTION = stop -o $ACTION = restart -o $ACTION = kill ] && ORDER="-r"
# wait up to 60 seconds to ensure that /opt partition is mounted
tmax=60
i=0
while [ $i -le $tmax ]; do
    if [ -d /opt/tmp ]; then
        break
    fi
    sleep 1
    let i++
done
for i in $(/opt/bin/find /opt/etc/init.d/ -perm '-u+x' -name 'S*' | sort $ORDER ) ;
do
    case "$i" in
        S* | *.sh )
            # Source shell script for speed.
            trap "" INT QUIT TSTP EXIT
            #set $1
            #echo "trying $i" >> /tmp/rc.log
            . $i $ACTION $CALLER
            # No sh extension, so fork subprocess.
            $i $ACTION $CALLER
    esac
done
thanks, fitz!
is it possible to put this "waiting loop" somewhere in /jffs/scripts ? i'm afraid that if i put it into /opt/etc/init.d/rc.unslung it will get overwritten by future entware updates...
got it:
in file /jffs/scripts/services-start
after this line
RC='/opt/etc/init.d/rc.unslung'
insert this code
### tmax=number of seconds to wait for partition to mount
tmax=60
i=0
if [ -d /mnt/YOURPARTITIONNAME ]; then
break
fi
sleep 1
let i++
done
now entware startup (which includes deluge startup) is delayed until my data partition is mounted. great!
Thought I remembered that one - still a nifty little trick...
(Bit of history - between the WRT54G and the NSLU2, there is so much DNA still left in modern devices that based on those two devices)
