admiral2145
is anyone using a usb fan on their ac68u to keep it cool? I saw a post awhile ago can cant remember what they used 2 cool the router via usb fan... I searched and did not find anything TIA
I am using this fan
http://www.staples.com/Deli-USB-Powered-Personal-Desk-Fan/product_219634
on an RT-AC56U and it has brought the temps from
2.4GHz 5GHz CPU
60C 60C 84C
To
2.4GHz 5GHz CPU
40C 40C 50C
But after reading a few posts by RMerlin, I may remove it (next time I'm there).
Some doc's indicate that the 'high' end may be 130C for these SOC's.
Had to comment on your handy work. Nice job clean looks like it was store bought..
You all know if you use the router stand so the router is vertical heat build up is not really an issue.
Welcome To SNBForums
