Usb hdd mount problem
kiesa1231
Hello all i installed entware in mnt/sda1 But asus somtimes mount after turn on to mnt/sdb1.Hdd file system fromated to ext3 only one partition.How setup to force mount only mnt/sda1 on first usb port or second port?Now hdd connected to usb port 1.Please help thanks
It is well known "feature". Use labels to access usb disks.
I'm curious about the labeling. I'm not familiar with the linux environment, and I have read that a script would need to be executed upon the router bootup to assign the label to the drive.
If the drive is tied to /dev/sda1 upon making the labeling script, and then after a reboot the drive is then assigned to /dev/sdb1, how is the script now going to point to the proper drive?
Perhaps I misinterpreted the script syntax, but is there a variable used to obtain the drive? How can the script distinguish between one USB device and another if I were to swap a different USB drive in the same slot?
I think you have your wires crossed there. You only need to label (unique,no spaces) once. Mounts are then tmp/mnt/Label instead of dynamic tmp/mnt/sd..
The easiest way to label a disk is directly from terminal:
tune2fs -L "[COLOR="Red"]desired_label_here[/COLOR]" /dev/sda1
reboot
To remove label
tune2fs -L "" /dev/sda1
reboot
