USB Wireless Card
Rapp
Just moved house and looking at getting a ASUS RT-N66U, however I also want to upgrade my USB wireless card for my PC as my current one likes to bsod when you put a large amount of traffic through it.
Does anyone have any recommendations on what to use with the above router?
Has anyone got or tried the ASUS USB-N66?
Thanks for the help.
I use Linksys RE1000 dual band one. 10.00 from eBay. It works well with upto Windows 8
and on Linux.
Thanks for the reply but that looks like it is a wireless range extender though, which isn't what I'm after.
I'm just looking for what people are using for their wireless cards before I buy another one.
I was looking at this
Thanks for the suggestion but I think that model is a little bit expensive compared to the model I was looking at for not much gain.
