Hey guys,
Not sure if this is a bug, or my hard drive is about to die. I've got over 100GB of files I'm trying to move from my Macbook to my USB3 drive shared on my AC87U over ethernet. The same Macbook is downloading files at 4MB/s. I've got 14 other wireless clients, but nothing else noteworthy using bandwidth.
Last night I started moving the files and noticed that after 5-10mins, the router appeared to crash/hang. I couldn't manage it wireless or over ethernet so turned it off/on.
The file copy started again (it's an automated job), and it happened again, 5-10 mins later. Turned it off/on and dug into the logs, finding this;
Sep 29 09:12:25 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Sep 29 09:12:25 kernel: sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Sep 29 09:12:25 kernel: sd 0:0:0:0: [sda] Sense Key : Illegal Request [current]
Sep 29 09:12:25 kernel: sd 0:0:0:0: [sda] Add. Sense: Invalid command operation code
Sep 29 09:12:25 kernel: sd 0:0:0:0: [sda] CDB: Write same(16): 93 08 00 00 00 00 6c 7c 45 78 00 00 01 d8 00 00
Sep 29 09:12:25 kernel: end_request: I/O error, dev sda, sector 1820083576
Doing a quick google, it would suggest there is either a problem with the disk https://vip.asus.com/forum/view.asp...R&id=20141224042950486&page=1&SLanguage=en-us, or a USB3/2 bug -> https://ubuntuforums.org/archive/index.php/t-1642641.html
Not really sure where to start...
