matthew_eli
Hi Merlin, and first of all, thank for your hard work!
I've encountered a problem updating my RT-N66U to RT-AC68U and it is the USB3 hard disk I already have (2TB Toshiba USB3.0 external hard drive Stor.E Canvio). No problem so far with RT-N66U. With RT-AC68U when I turn on the router by pushing the power-on button and I leave the Hard Disk attached in the USB3 port, it wouldn't be mounted and I get these messages on the log:
At this point trying to detach and attach the hard disk on the same port (USB3) does not fix the issue; instead, attaching it on the USB2 port, solve the problem and the hard disk would be mounted normally. For correctly mounting the hard disk on the USB3 port at the fist try, I need to plug it only after a while the router has been rebooted.
It goes without saying that once the hard disk is correctly mounted, it works flawlessly.
Could you help me fixing this problem? I tried your firmware .37 and .38 and they both suffers the same issue
Jan 12 09:54:16 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 12 09:54:17 kernel: usb 1-1: Device not responding to set address.
Jan 12 09:54:17 kernel: usb 1-1: device not accepting address 0, error -71
Jan 12 09:54:18 kernel: usb 1-1: Device not responding to set address.
Jan 12 09:54:18 kernel: usb 1-1: device not accepting address 0, error -71
