Can you use an USB Wifi antena (not those with port like the coaxial cable) for your router to extend and have more powerful Wifi. Some routers have attached antenna that you can't remove them and replace with stronger anttena that you can find on internet. For the routers that have ports where you can mount easy an external antenna like those ports that look like the coacial cable, it is simple that you can change easily the antenna. What about those other routers that you can't change their antenna because they don't have this kind of ports where you can mount external antenna like in this image:
If your router doesnt have this chance, can you use the USB port of the router to mount there a USB Wifi antenna that works for routers. I am asking because these USB Wifi antenna are mainly for computers and you install them by installng even a driver in the computer in order to work this antennas. My questions are:
-Is there any USB Wifi external antenna that you can mount easily in the USB port of the router to have a stronger wifi.
-Can you use those USB Wifi antennas used for computers even for the routers (those USB Wifi antennas usually need to install a driver to work.
