User scripts are not called at reboot
Sharbe
Hello guys, I need some help, please.
ASUS RT-N66U with latest Merlin's build.
I placed the "Scheduled LED control" scripts in /jfss/scripts/ , and afterwards chmod it to a+rx.
I also added nat-start and wan-start to get direct access to my modems webGUI.
When I run the scripts manually via telnet, it runs like expected, but the scripts are not called at reboot.
So, what could be wrong?
Thanks in advance,
Sharbe
...you need to integrate the trigger into the services-start script, as stated on git.
Next, either create the following services-start script (or add to any existing script):
services-start:
#!/bin/sh
cru a lightsoff "0 18 * * * /jffs/scripts/ledsoff.sh"
cru a lightson "0 6 * * * /jffs/scripts/ledson.sh"
I followed the guide Scheduled LED control as stated on git.
I had created services-start, ledson.sh, ledsoff.sh. Then saved them in /jffs/scripts/ and afterwards chmod all scripts to a+rx.
Then, I have had reboot my router.
To confirm that the jobs are properly set up I had run the following command through telnet:
cru l
None of the scheduled tasks had listed.
After running the scripts manually I checked "cru l" again and all tasks had listed now.
To test it again, I rebooted the router once more, but again none of the tasks were run after reboot :(...
Hmm....strange.
Just to confirm...when running the single services-start script manually, the led-scripts get triggered successfully?
I restarted my router again just to check it:
See my telnet log, please:
RT-N66U login: admin
Password:
ASUSWRT-Merlin RT-N66U_3.0.0.4 Fri Jan 31 05:20:15 UTC 2014
admin@RT-N66U:/tmp/home/root# cru l
admin@RT-N66U:/tmp/home/root# /jffs/scripts/services-start
30 23 * * * /jffs/scripts/ledsoff.sh #lightsoff#
45 5 * * * /jffs/scripts/ledson.sh #lightson#
I have no idea what is running wrong here ...
Password:
Post the output of the following commands:
mount
ls   -l   /jffs
ls   -l   /jffs/scripts
Regards,
Here we go:
Password:
admin@RT-N66U:/tmp/home/root# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw)
admin@RT-N66U:/tmp/home/root# ls -l /jffs
drwxr-xr-x    2 admin    root             0 Jan  1  2011 configs
drwxr-xr-x    2 admin    root             0 Feb 17 16:53 scripts
admin@RT-N66U:/tmp/home/root# ls -l /jffs/scripts/
-rwxrwxrwx    1 admin    root            81 Feb 17 16:53 ledsoff.sh
-rwxrwxrwx    1 admin    root            79 Feb 17 16:53 ledson.sh
-rwxrwxrwx    1 admin    root           536 Feb 17 16:52 nat-start
-rwxrwxrwx    1 admin    root           228 Feb 17 16:53 services-start
-rwxrwxrwx    1 admin    root           843 Feb 17 16:53 wan-start
Here we go:
Password:
Well, if the router clearly shows that JFFS is ACTIVE as per the screenshot,
then if the following
cd /jffs/scripts
./services-start
shows no errors, and U have included trace ('logger' or 'echo') statements that appear as expected, then there must be a problem locating the script files at boot time?
Regards,
if in doubt use WinSCP to create the files direct in the JFFS folder, worked for me when things didn't go to plan.
Could be a line end problem with the script.
Also, try cru with the complete path.
@Martineau: JFFS is ACTIVE as per the example screenshot.
I will add statements to the files later. Please find my current files attached.
@GoNz0: Never used WinSCP before. Maybe I will have some time at the weekend to give it a try.
@lancer73: Could you please give me the whole command. I am sorry I am not an experienced linux user. it is more ... monkey see, monkey do ...
Make sure the first line of ALL your scripts is ALWAYS:
#!/bin/sh
Regards,
