paranoised
I got my hands on an AVM FRITZ!Powerline 1200E, however this set was designed for a European socket CEE 7/4 (Type F) whereas the plugs used here are the British Type G variety.
Using a simple travel adapter allows the device to run since voltage conversion is unnecessary, however the ground contacts are not connected and as such the MIMO capability of this device is gone to waste.
My questions are as follows: Is there a way to make this work given my situation? Is it as simple as installing and wiring up a German style power socket in place of the existing British style socket? Are there any adapters sold that would do this in a neater fashion?
If all else fails, I could always offload it to someone that can make better use of it.
