Using a Network Switch between WAN and LAN
travial
First post here, but thanks for all the previous help here just browsing the forums while researching a network bridge between two houses. Here's my new problem:
My comcast modem is at one end of my house, and I've run 100ft Cat5e cable to the other end where my wireless router is. My xBox resides right next to my Comcast modem, but it's running off the wifi from the wireless router from the other side of the house, resulting in occasional slow performance when playing games. I would really like to avoid running another 100ft cable all the way back through the house to the xBox, and it seems redundant with the modem right there next to it. I need to leave my router at the other end bc it's sharing internet with the next house via directional antenna. My question is:
Can I get a network switch and just plug my WAN Ethernet cable, my xBox, and my wireless router into it and everything will work right? Thinking about it, I'm not sure if the router could assign an IP to my xBox back through the WAN port of the router though.
So assuming it doesn't work, if I get a wired router instead of a network switch, will any old 10/100Mbps router be able to deliver real throughput speeds of 50Mbps, or should I look for a gigabit router?
Right now my setup is:
Comcast modem in the back of house w/ 50Mbps speed (next to xBox).
ASUS RT-AC66U router in the front w/ directional antenna pointing at my sister's house. (So I can't move it.)
Any advice greatly appreciated, thanks.
Buy a small router (no WiFi needed ) connect the WAN port to your modem. Then connect your XBOX and the100 ft cable to LAN ports.
Connect the other end of your 100 ft cable to a LAN port on your ASUS. Then run your ASUS in the AP mode. You will be good to go.
As an alternative you could use another router with WiFi at the location connected to the modem.
Sent from my KFTT using Tapatalk
Thanks Captain, the more I thought about it the better that option sounds. I've got an old Netgear wndr3400v2 router sitting around with DD-WRT that I should be able to re-purpose for this that I forgot about too.
