Hello, I would like to use a VPN to secure some of my internet traffic. But from what I understand, if I simply enable OpenVPN on my router, and connect to a VPN, it will route traffic through the VPN on a per machine basis.
I only want to send some of my traffic through the VPN (web browser, for example). So I though I could try to set up a proxy server on my router as well. Then I can selectively send traffic to my own proxy server, and have all of the proxy server's traffic routed through the VPN.
I don't even know if my understanding of the situation is correct. I'm been stumbling around, reading guides and articles on the subject for about ten hours now. Is my intended set up even reasonable?
I installed entware on my RT-AC66U running ASUSWRT-Merlin, and then I tried to install Privoxy. I am aware that the file system for the router is a bit different then linux would normally use, but when I try to start Privoxy I am told:
zelklen@RT-AC66U-04A0:/tmp/mnt/entware/entware/sbin# privoxy start
2018-06-30 13:18:50.228 2aab0310 Fatal error: can't check configuration file '/tmp/mnt/entware/entware/sbin/start': No such file or directory
Which makes perfect sense, because there is no start file or directory there:
zelklen@RT-AC66U-04A0:/tmp/mnt/entware/entware/sbin# ls
ldconfig privoxy
I don't know how to proceed. Currently, I tried simply touching a "config" file, and then it will let me start Privoxy, and I can see it running in top, but I can't seem to do anything with it, and it definitely doesn't show up on the clients list of the router. So I'm trying to just write a privoxy config file by hand, following what Privoxy has for documentation on their website. Maybe it will work, maybe it wont. I would love to get some help.
ldconfig privoxy
