OzarkEdge
Part of the Furniture
I've added a wired backhaul MoCA 2.5Gbps to my AiMesh, limited to 1GbE at the AC86U node WAN port. This wired backhaul has 3 segments, Ethernet at each end and MoCA in the middle. The AiMesh Ethernet Backhaul Mode system setting is set to the default disabled.
Some observations...
A) If the node Backhaul Connection Priority is set to the default Auto, then breaking any segment of the wired backhaul will cause failover to wireless backhaul. Good!
B) If the node Backhaul Connection Priority is set to WAN/Ethernet first, then only breaking the node Ethernet segment will cause failover to wireless backhaul. Not good enough! (Same might apply to any wired backhaul with multiple Ethernet segments/switches?)
C) When a wireless backhaul is active, its connection details appear in the Wireless Log. When a wireless backhaul is not active, its connection details eventually disappear from the Wireless Log. This suggests no WiFi is shared/reserved for a wireless backhaul until it is actually required for a wireless backhaul. This appears to be good!
Given the above, if I want the best backhaul and failover to the alternate backhaul, I should leave the node Backhaul Connection Priority set to the default Auto. And I should leave the AiMesh Ethernet Backhaul Mode set to the default disable and expect all WiFi to be available for clients until a wireless backhaul is actually active.
Perhaps someone has additional insight or can explain their non-default use of these settings.
OE
OE
