Using ASUS Router as a Hub
GeorgeRace
I am new to this forum and have a question on using a router as a hub.
Here is what I want to do. I want to use WireShark to monitor all the internet tracffic on my network. My main router is a RT-AC68U. I have a RT-N16 that I want to configure as a HUB and connect it between my ISP MODEM and the AC68U. (Both routers are ASUS)
Doing that I will be able to use a laptop connected to the N16 to monitor all traffic from and to the internet using WireShark.
I guess I am thick headed when it comes to setting up the parameters I need in the N16 to make it act as a HUB. I have found some examples on the web but there is never enough "step by step" detail for me to follow to make it work.
So far no matter what I tried it just will not work the way I want. I can get the N16 it to pass the internet through, but I always end up with my wireless AC68U network connections somehow attached to the N16, even though the wireless signal is coming from the AC68U. And yes, I do have the wireless turned off in the N16.
I am connecting the ISP MODEM cable to the WAN port on the N16 then connecting one of the LAN ports on the N16 to the WAN port on the AC68U. So I know the "HUB" is setting between the internet and the AC68U Router.
Boy, am I ever confused I guess.
Any help with setting up the N16 to act as a hub would be appreciated.
Thanks,
New User George
Ethernet Ports are switched...
If you're trying to capture WiFi packets, you need to load your keys into Wireshark, but I don't think that'll fully solve the problem, you might have to disable WPA2, and run the WiFi without auth, and there you can collect packets over the air...
This is one reason why I have an old 10BaseT hub on the shelf...
