I have a wireless router on hand that I would like to use for a wired application only. It will be installed in a shielded structured wiring cabinet. I have two wireless access points, I will hard wire to the router. The question is if I uncheck the "enable wireless radio box" on the router web page, does it actually power down and disable the radio or just disconnect the radio from the network while allowing the radio to still broadcast a signal?
Welcome To SNBForums
