But they can provide better protection against email-based threats at least.
Wouldn't a UTM do that?You'd have to use a POP/IMAP/SMTP gateway to handle threat handling.
thiggins: For HTTPS inspection the appliance is the requester of the url not the computer. The end system sends the request to the appliance, the appliance then acts as the requester. The request is sent back to the appliance and in turn it inspects and passes it on. The device will need a certificate from the appliance for this to work. A good example of this would be the eicar test file in various forms. with https inspection on the test files in all forms get blocked / rejected at the firewall. http, https, zip and such.
I also forgot to mention I have XG set up to inspect small downloads before it allows them to pass.
But again, some sites and applications or games do not play well with this so I either have to whitelist them or just have the device on a rule that dose not use https inspections. My Roku would be an example of not playing well so I have it set up on a separate firewall rule.
Thats where url blacklisting comes into play. I can import lists of urls I wish to block at the firewall from the reports I get or from someonewhocares.org and use their url list.
Dumb (perhaps) question. How do things like ASUS AIProtection, Bitdefender Box, Cujo and other "dumbed-down" boxes compare? I'm especially interested in ASUS AIProtection (Trend Micro) - which apparently does deep-packet inspection.
Untangle or pfsense/snort seem useful, but I'm getting older and it is hard to find time to "tinker" like I used to. Still, I don't want to be "naked on the 'net". Note: I don't expose any ports; just looking for safe broadband access, at home.
Welcome To SNBForums
