Verizon FiOS blocking ISAKMP for TMo femtocell?
David Gursky
I havc a [T-Mobile supplied] femtocell (a Nokia SS2FII). [Actually, I have two -- one here at my home in VA, another at SWMBO's home in MD.]
About four months ago, the VA unit stopped connection to TMo, and the MD unit followed suit about a month ago. I worked with TMo to try and ascertain the problem, to no avail. I have now inserted a protocol analyzer between the VA unit and my home router, and it appears that the Cellspot is trying to initiate an ISAKMP session to a TMo server (serving1tep1-4sgwphi21-22.smallcell.t-mobile.com -- who comes up with these names anyhow???) but it seems to go nowhere -- the request is initiated, but there is no acknowledgement.
What is even odder is that I get different results from traceroute. On my protocol analyzer, I get this:
Tracing route to serving1tep1-4sgwphi21-22.smallcell.t-mobile.com [208.54.90.15]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms RT-AC66U_B1-D290.gursky.home [192.168.60.1]
2 1 ms 1 ms <1 ms 208.54.90.15
Trace complete.
On my primary router, I get this:
traceroute to serving1tep1-4sgwphi21-22.smallcell.t-mobile.com (208.54.90.11), 30 hops max, 38 byte packets
1 * * *
2 B3365.WASHDC-LCR-22.verizon-gni.net (100.41.136.160) 2.902 ms 4.130 ms B3365.WASHDC-LCR-21.verizon-gni.net (100.41.136.158) 4.417 ms
3 * * *
4 0.ae1.BR1.IAD8.ALTER.NET (140.222.239.77) 3.438 ms 3.528 ms 4.020 ms
5 xe-2-1-0.er2.iad10.us.zip.zayo.com (64.125.13.173) 2.993 ms 3.862 ms 3.075 ms
6 ae1.cs4.iad93.us.zip.zayo.com (64.125.25.164) 10.367 ms * *
7 ae9.cs2.dca2.us.eth.zayo.com (64.125.25.100) 21.760 ms 8.174 ms 8.618 ms
8 ae5.mpr4.phl2.us.zip.zayo.com (64.125.30.57) 8.967 ms 9.473 ms 9.864 ms
9 ae4.mpr3.phl2.us.zip.zayo.com (64.125.21.73) 9.612 ms 8.353 ms 9.118 ms
10 * * *
11 * * *
12 * * *
13 * * *
14 208.54.90.11 (208.54.90.11) 20.013 ms 26.279 ms 9.955 ms
[Both 90.11 and 90.15 are IP addresses to serving1tep1, that's not what's odd, it is the VERY different results.]
Thoughts? Help!
I believe I have finally found the problem here. Both my Verizon supplied Quantum Router and my ASUS RT-AC66U (running Merlin) block IPSEC by default. Enable IPSEC passthrough and it seems MUCH happier.
Maybe you accidentally changed that setting on the Asus sometime in the past. The default setting for IPSec Passthrough is enabled.
SWMBO = She Who Must Be Obeyed, for those scratching their heads before they hit google.
