Working from home I needed to upgrade the Modem for higher internet speed and I thought upgrading my router it may be a good idea. It was not, at least for NETGEAR Nighthawk AX5200 Wi-Fi 6 Router (RAX48) I bought. I currently use a seven year old NETGEAR Nighthawk AC1900 model R7000.
Here is the comparison: Second floor R7000 signal strength is 85-90% and connection speed 433 Mbps (using wi-fi Netgear A6100 Genie USB adaptor). New router AX5200 signal strength is 70-75% and connection speed 195 Mbps. Huge degradation.
My one-year-old tablet cannot detect the 5G signal and the only option is to connect on 2.4G. I moved it to the first floor and I was able to connect to 5G, but it lost signal upstairs.
At first floor where my old R7000 measure 100% signal strength regardless of location while AX5200 signal strength was 70 to 95% depending on location. Also, I have an old laptop that is connecting to 2.4G only, the R7000 connection speed was 150Mbps while AX5200 cannot go higher than 72Mbps. In basement the R7000 signal strength was solid 100% regardless of location, while the AX5200 delivered just 50-70% depending on location. I believe that if I buy the cheapest router, below $40 I may get same or better performance than AX5200. I mention that I have not changed the Modem & Router location, just unplug the old router and wire the new one. I already returned the AX5200.
How would you rate my current R7000 performance? Do I need a replacement, or better say are there on the market better routers? And if there are, it worth the investment? Can I notice an improvement?
If my router dies tomorrow what can I buy to be al least similar performance to current R7000?
