1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Very Small, Very Simple NAS or Built In Router USB
Discussion in 'NAS Buying Advice' started by Anotherusername, Oct 21, 2017.
  1. Anotherusername
    Anotherusername Occasional Visitor
    May 4, 2015
    16
    Hello- Thank you in advance for your help.
    Anyone recommend a very simple NAS solution. It would be awesome if I could just use a memory stick.
    Here's the need:
    - 20 clients saving very very small text files (as in 25KB) 1 time an hour- Very light workload
    - Transportable- Size matters- It gets shipped within shipping crates
    I've tried to simply use different router's built in USB file sharing, but most seem to max out at between 5-10 connections to the USB port. So, If you have a recommendation of a router that is pretty small (these machines do not connect to the internet. They just share files) and allows 20 connections to the usb port, this would probably work great.
    Thanks!
  2. Please support SNBForums! Just click on this link before you buy something from Amazon and we'll get a small commission on anything you buy. Thanks!
  3. sfx2000
    sfx2000 Part of the Furniture
    Aug 11, 2011
    13,491
    San Diego, CA
    Win 10 Pro on a corp grade laptop (think Thinkpad 430 or equivalent from Dell/HP/etc...).
    Can set up a file share there...
  4. Anotherusername
    May 4, 2015
    16
    Yes, thank you for mentioning it. All the documentation I could find said that the maximum connections is 10. I've thought about bringing a small build PC with me, but that just feels really complicated and again, I hit the 10 limit.
    Does Win10 Pro lift the 10 limit?
    Thanks!!
  5. sfx2000
    Aug 11, 2011
    13,491
    San Diego, CA
    I think Win10 Pro is still limited to 10 concurrent sessions...
    Another idea would be to set up an Intel NUC using Ubuntu and Samba - fairly easy to set up a simple Samba server in about 20 lines of configuration...
  6. Anotherusername
    May 4, 2015
    16
    That's an idea. Or even a RaspberryPi. Or if I end up in this direction, I could just go with a Synology single bay DiskStation (https://www.synology.com/en-us/products/DS115j). I was just trying to avoid a big 3.5" disk solution. I know I have an edge case, but it is what it is.
    This is why I was looking for a router that allows 20 clients via SMB, but it seems hard to find.
    Thanks!
  7. thiggins
    thiggins Mr. Easy Staff Member
    May 18, 2008
    13,602
    There are the Seagate Wireless and Wireless Plus if you can live with only wireless access.
    Also this and this. Some of these devices say they stream to up to 5 devices. Not sure that is a connection limit or guidance on how many devices will stream smoothly.
  8. Anotherusername
    May 4, 2015
    16
    Yes! Thank you! I think these will work terrific. Thanks a ton. I have probably spent 2-3hrs of searching to find something exactly like these solutions. Many thanks for this. I'll experiment and report back.
    Thanks again!
  9. Anotherusername
    May 4, 2015
    16
  10. sfx2000
    Aug 11, 2011
    13,491
    San Diego, CA
  11. Anotherusername
    May 4, 2015
    16
    Thanks. Good to know.
    I did some research last night and from what it looks like, Microsoft upped the shared folder maximum connections from 10 to 20. It was installed within a service update at some point during Windows 7.
    So, I'm going to test this out tomorrow (Monday) and I'll report back. Thanks for everyone's input.
  12. Anotherusername
    May 4, 2015
    16
    Hi Everyone- Ok, wanted to report back.
    I setup 20 laptops connected to my Lenovo x201 i7 Win 7 machine. Worked no problem. Can't even notice the performance hit whatsoever. As soon as I tried to connect #21- Would not let me.
    Thank you for your help with this! Very helpful to me.
    ColinTaylor likes this.
