VERY suspicious iptables entries... please help...
recharging
Apologies for reopening this thread from Leo Martin Lim.
The offending entries in the ASUS Merlin iptables are as follows:
Chain OUTPUT_IP (1 references)
num target prot opt source destination
1 logdrop_ip all -- anywhere 193.201.224.0/24
2 logdrop_ip all -- anywhere vriezekolk.org
3 logdrop_ip all -- anywhere li1019-134.members.linode.com
4 logdrop_ip all -- anywhere 190.115.18.28
5 logdrop_ip all -- anywhere 51-159-52-250.rev.poneytelecom.eu
6 logdrop_ip all -- anywhere 190.115.18.86
What does it actually do? Log every attempt to access any of the above sites? The sites are still accessible though.
They are hard-coded entries added by Asus. They prevent the router (not LAN clients) from accessing those addresses because they've been identified as a security issue.
It will create an entry in the syslog if the router attempts to go to one of those addresses. For example,
Apr 22 10:54:06 kernel: DROP_IP IN= OUT=eth0 SRC=80.7.XXX.YYY DST=51.15.120.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=27205 DF PROTO=TCP SPT=57128 DPT=80 SEQ=300254509 ACK=0 WINDOW=29200 RES=0x00 SYN URGP=0 OPT (020405B40402080A02D9EF680000000001030307)
Apr 22 10:54:07 kernel: DROP_IP IN= OUT=eth0 SRC=80.7.XXX.YYY DST=51.15.120.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=27206 DF PROTO=TCP SPT=57128 DPT=80 SEQ=300254509 ACK=0 WINDOW=29200 RES=0x00 SYN URGP=0 OPT (020405B40402080A02D9F3660000000001030307)
Apr 22 10:54:09 kernel: DROP_IP IN= OUT=eth0 SRC=80.7.XXX.YYY DST=51.15.120.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=27207 DF PROTO=TCP SPT=57128 DPT=80 SEQ=300254509 ACK=0 WINDOW=29200 RES=0x00 SYN URGP=0 OPT (020405B40402080A02D9FB500000000001030307)
Apr 22 10:54:13 kernel: DROP_IP IN= OUT=eth0 SRC=80.7.XXX.YYY DST=51.15.120.245 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=27208 DF PROTO=TCP SPT=57128 DPT=80 SEQ=300254509 ACK=0 WINDOW=29200 RES=0x00 SYN URGP=0 OPT (020405B40402080A02DA0B100000000001030307)
