View Log of Asus Mesh Node??
BobM351
Is there a way to view the log of a client Mesh Node? I know the IP address. The WiFi on my client node stops working but the ethernet continues to work. I would like to view the log while it is happening to see if I can figure out what is going on. The main node doesn't tell me anything. Thanks
icsa
If you connect to the node over ssh using its IP address, the log is in /tmp/syslog.log
