Hi, I have the Costco version of the X6S and I am trying to setup one of the LAN ports as a VLAN - I essentially need to connect a device that needs to be separated from the rest of the network.
I think I have felt for the marketing - it says "vlan support" but looking at the manual, it looks like it can do vlan tagging only.
So my question is:
1) is my assumption above correct?
2) Can it be mitigated by flashing some other version/branch of the firmware?
3) If I am hosed and need to sell it, what router would you recommend (need great Wifi coverage and bandwidth), VLAN on the LAN ports, built-in VPN and not cost me arm and leg)
Thank you!
So my question is:
Thank you!
