canuck in the wilderness
I have two Asus-Merlin routers on two separate public static IPs through the same modem. (Note: I'm rural, and connected to the modem via a radio link which acts basically like a long ethernet cable from my location to the modem, which is in a nearby town.) Let's call the IPs 006 (N66U) and 007 (AC68U).
The modem connects to a Negear switch which is VLANned and distributes the two public IPs to two separate routers (long story).
I used to be able to (a) ping from one IP to the other, usually from 006 to 007 and (b) connect via Remote Desktop to PCs on each end, again most importantly from 006 to 007.
Now, "something" has happened and I can do neither. Connecting from the outside world works fine, both for ping and RDP, so I'm suspecting I inadvertently changed that "something" that now has screwed up my ability to treat the two routers as if they really were in two different locations. (I had to rebuild the switch so that may be the problem.)
I assume that somehow rather than the connections between the two being made outside and on the internet (as if they were indeed in two different locations), it's being made internally in the switch. Does that make sense?
Can anyone advise how to start debugging this?
