Vodafone IPTV - Vlans 100,101,105
EditioN
Hi There!
Have here a small question that I guess you guys can answer me :)
Basically I receive 3 vlans from my ISP:
100 - Internet
101 - VoIP
105 - IPTV
Since I have two STB's and I want to avoid to connect a switch, I need to have vlan 100,101,105 tagged at WAN and vlan 105 untagged in 2 ports, vlan 101 in another port and the last one can stay in vlan (let's say 1).
I have this scenario working in Tomato using nvram commands but I'm not able to do it in asuswrt with vlans >15. Tried the ISP profile but I only have option for 2 ports (LAN3 and LAN4).
Any idea?
Appreciate the help!
Thanks.
Hey, no ideas?
From what I searched maybe I can use this commands?
robocfg vlan 101 ports "3 4t 5"
robocfg vlan 105 ports "1 2 4t 5"
This way I would have:
Vlan 101 tagged in WAN port and untagged at port 3
Vlan 105 tagged in WAN port and untagged at port 1,2
Port 0 would stay in vlan1
Is this the right/only way to do it?
Thanks.
You can edit nvram directly. That is what I did.
Check it. Nvram show | grep vlan
Hey there, thanks for the input.
The problem is that when I edit nvram directly it doesn't work with vlans above vlan 15.
I tried creating them like this:
vlan101hwname=et0
vlan101ports="1 4t 5"
And like this too, that works in Tomato:
vlan4ports=0t 4t 5
vlan4vid=101
vlan4hwname=et0
But neither works in AsusWRT :|
Just to add after some months.. :D
Ended up solving the problem with a script in jffs partition, I used "nat-start" with robocfg:
robocfg vlan 101 ports "0t 4t 5"
robocfg vlan 105 ports "2 3 4t 5"
Port 2 and 3 are used for the STBs, untagged vlan 105
Port 0 tagged with vlan 101 for VOiP
and the rest with vlan1 as default.
