VoIP ports used in Adaptive-QoS
R1-Limited
I am in the middle of a task to qualify the Asus RT-ac series routers for use with our products. In the qualification I am establishing two areas of firmware, Asus and Merlin-WRT so I need to know as I establish both profiles and setups for QoS that I get the ports that are standard in Adaptive. Traditional I understand I can add, just need to make sure there is no missing service from the Adaptive drag and drop VoIP Module (I will call it) vs adding what we require.
Also just a note to Merlin, maybe incorporate in your firmware for Traditional-QoS a drop down category for VoIP with the most standard ports etc.
Appreciate the answer
There is more voip ports that just 5060 which is the default only port in adaptive. Asus needs to step up on this one and actually add RTP, UDP and associated standard ports used by Most VoIP OEM. Aka 6060, 6061, RDP port ranges etc. My final dox we will not support Adaptive because it caused sever jitter and delay. Using Traditional was the best option
