Hi all,
Using Voxel's firmware on the R9000, since V1.0.4.47 and the last before (I think, could be a bit longer) updates, I've run into an issue with the OpenVPN server.
The LAN runs on 192.168.3.xxx, and I have a device on .100
Clients connected through the VPN (tap) cannot make a connection to this .100 device, not even a ping. Connecting to any other devices works fine (.110, .92), just this .100 device! It's got me confused
. AFAIK the openVPN server doesn't run on .100 does it? Anything else that could cause this? I could move the device but several others on the network connect to it so it'd be a bit of doing. Surely it's a simple configuration thing somewhere
And on the openVPN subject, I'd prefer to run the server on port 443. Currently, this doesn't work. I read that this is a Netgear limitation (conflict with their hard coding of the router interface I guess), but perhaps with Voxel it's possible to fix this? I couldn't find anything on it.
Oh, and just curiosity, but offtopic, I couldn't find this in the changelog, but what happened to the HW builds? No benefit anymore?
Thanks again!
Thanks again!
