VPN behavior with multiple clients
fbicknel
This was odd. Maybe someone can explain why this happens.
I have two VPN clients configured: a primary in use and a secondary that's turned off. (I figure I can more easily switch to the secondary if the primary fails for some reason. I've had to do this a couple of times when the primary threw an authentication error.)
I just added a new IoT subnet that requires no VPNs. I'll probably post another to discuss firewalling. So I'm here to configure the VPN this morning. I went to my primary:
and added a new entry titled IDIoT:
This lists my IoT subnet f.o.o.0/24 and designates the interface as WAN.
Hopefully I got that right.
Anyway, not the issue.
Then I went to my secondary client:
And it had already added my f.o.o.0/24 subnet but check out the description it gave it:
I mean, this isn't going to affect the operation here... but why did it change the description to Secondary?
