Hello,
I have a problem with my setup consisting of two ASUS routers which are connected via internet.
The setup is as follows:
The ovpn config is as follows:
remote x.x.x.x 443
float
nobind
proto udp
dev tap
route-gateway 192.168.100.1
;dev-node MyTap
sndbuf 0
rcvbuf 0
keepalive 15 60
comp-lzo adaptive
auth-user-pass
client
auth SHA1
cipher AES-256-CBC
For the VPN server:
Respond to DNS: Yes
Advertise DNS to clients: Yes
Allocate from DHCP: yes
Direct clients to redirect Internet traffic: yes
A's IP is 192.168.100.1,
B's IP is 192.168.100.2
Both routers have DHCP servers enabled.
A's DHCP
IP Pool Starting Address : 192.168.100.50
IP Pool Ending Address: 192.168.100.200
Default gateway: 192.168.100.1
B's DHCP
IP Pool Starting Address : 192.168.100.201
IP Pool Ending Address: 192.168.100.254
Default gateway: 192.168.100.2
After activating the VPN client profile on Router B, Windows 7 client connected to B works fine, but Windows 10 doesn't work.
Android clients work for some time, but then they loose internet connection.
And after disabling the VPN client profile usually internet disappears from all clients.
I have tried changing different DNS settings but couldn't make it work reliably.
What is wrong with my setup?
Thanks.
- Router A: RT-AC87U, which runs an OpenVPN server
- Router B: RT-AC68U, which runs a VPN Client
remote x.x.x.x 443
float
nobind
proto udp
dev tap
;dev-node MyTap
sndbuf 0
rcvbuf 0
keepalive 15 60
comp-lzo adaptive
auth-user-pass
client
auth SHA1
cipher AES-256-CBC
For the VPN server:
Respond to DNS: Yes
A's DHCP
B's DHCP
Thanks.
