Hi all,
Is it possible using the Asus Merlin firmware to set a specific workstation up on the LAN to route it's traffic through a VPN connection which has been setup on the Asus router? the rest of the work stations on the LAN to bypass the VPN settings and go out on the web as normal?
EDIT: I've just seen in the patch notes there is a feature called 'policy routing' where can i find this?
