VPN Client - Use only for specific client
mekabe remain
is there an addon which would enable use of VPN (client) by only specific network clients ?
I mean after connecting the router to a VPN server, that route would be used only by specified network clients.
is there such feature/addon ?
thx
ColinTaylor
Part of the Furniture
No need for an addon it's built into the firmware's GUI.
L&LD
Did you study the link provided above?
mekabe remain
I don't see "Redirect Internet traffic" on the VPN Client configuration page.
which version of Merlin WRT FW has that ?
eibgrad
It's actually the "Force Internet traffic through tunnel" option, from which you select Policy Rules. The "Redirect Internet traffic" option is an old reference that should be updated in the documentation.
L&LD
Which router and firmware do you have?
Sobster88
You must select force internet traffic through tunnel and then add your clients IP in the section below. You will need to set a static IP for the client.
