VPN for a single device
W1nks
I was wondering if it would be possible to have a single devices (Roku) traffic go through OpenVPN? I want only that device to use the OpenVPN but none of the other devices on the network to. Is this possible to do using an ASUS router?
Thanks!
Thanks!
Yes it is. Use Policy Rules and on the VPN client and make a rule that only that device uses VPN
example: assuming the IP of you device is 192.168.1.50
Source IP 192.168.1.50 and destination IP 0.0.0.0 lface VPN
every other IP will use the local ISP except for 192.168.1.50
