VPN for only one channel?
Matsa
I have a ASUS RT-AC3200 running the latest Merlin software. I have a Apple TV connected to it and would like to have a VPN for the ATV only (VPN can not be configured in the ATV). So my question is if the is a way to configure that and dedicate the ATV only to that channel, and the rest to the "normal" network?
Assign static IP addresses to your LAN clients. In the VPN Client, select Policy Routing (Strict). Below that is the section where you can enter the clients that you want to use the VPN. The second part of the thread below explains how to do it.
https://www.snbforums.com/threads/h...a-and-other-vpn-providers-380-68-09-12.30851/
Great reply.
Also you may need to set this:
Accept DNS Configuration > Exclusive
I find this a useful test http://www.ipleak.net
