VPN issue 380.65
bkz81
Hello all.
I upgraded from 380.61 to 380.65. Has anybody gotten the VPN to work with the new version? I am using torguard. I applied all of the regular settings that torguard requires, but it is not starting. I see a few new options. I looked in the logs and saw the following below.
Feb 10 15:03:42 rc_service: httpds 1724:notify_rc start_vpnclient1
Feb 10 15:03:42 openvpn[1961]: Options error: Unrecognized option or missing or extra parameter(s) in config.ovpn:32: push (2.4.0)
Feb 10 15:03:42 openvpn[1961]: Use --help for more information.
Feb 10 15:03:42 syslog: VPN_LOG_ERROR: 522: Starting OpenVPN failed...
New Drop down menu options in 380.65
Cipher Negotiation - Enable (With Fallback) , disable, enable
Negotiable ciphers - AES-128-GCM:AES-256-GCM:AES-128-CBC:AES-256-CBC
Legacy/fallback cipher - (List of different ciphers)
Compression - Disabled, None, LZO, LZO Adaptive, LZ4
Hello all.
See this post: #114
Thanks, for the reply. I removed the config files that were imported from the .ovpn file. Then turn it back on and it worked.
