vpn newbie
aliitp
hi
am new to the whole VPN setup and would really like to use it that is for 2 reasons mostly:-
1) map an NAS device which is on my HOME WORKGROUP network, through a VPN tunnel to another remote PC... (Main Goal)
2) Privacy and anonymity...
I got a R7000 and it got that feature built in and i believe i configure it right:
http://grabilla.com/07708-7bddaff9-152d-4a09-b917-84ca24bae5ac.png
then OpenVPN ran fine:
http://grabilla.com/07708-8f41334c-98fd-498b-8986-90852568a179.png
but then what ??!...
am totally lost maybe because i didnt digest the entire concept of VPN , how do i connect to this PC from a remote location and mainly be able to see all machines on the workgroup and map[ some of them !...
any help or clarification is appreciated...
thanks,
First thing is to try to ping a device on the local LAN from the remote LAN.
hi
thanks,
read this guide and you will be able to achieve what you want.
https://www.snbforums.com/threads/h...th-asus-routers-380-66-6-updated-07-05.33638/
