I have the problem with "SIGTERM[soft,auth-failure] received, process exiting".
My network configuration: provider -> modem -> router(AC68U).
Randomly my provider down and up his connection with changing outside ip address. OpenVPN client on my router trying reconnect but due to different outside ip address it can't with "SIGTERM" message. If I manually press button "turn VPN on" then all works ok.
auth-nocache and keepalive not help. Current installed build is 380.66_6
Found something into the logs:
"AUTH: Received control message: AUTH_FAILED,SESSION: Your session has expired, please reauthenticate"
